Results 1 to 5 of 5
Thread: dr 650 valve adjustment
  1. #1
    BE EF
    Post imported post
    How do I know if i need to adjust the valves on my bike?? I have put 11 000 Kms on since new and haven't adjusted them yet.Also, how difficult is it are are there any tricks of the trade? Thanks for your expertise!!Happy riding.
  2. #2
    Senior Member
    Join Date
    Oct 2006
    Bike(s)
    '04 DR650
    Posts
    1,067
    Post imported post
    It's rather easy. Tips and tricks. #1 Long feeler gauges bent slightly. #2 Use head of robertson srcew to make adjustment. #3 EngineMUST bestone cold to make proper adjustment, however to make life easier loosen access plug on magneto cover(where you put socket to turn over engine to line up timing mark)when bike is hot, then apply never seize upon re-assembly.
    When I checked mine at the recommended 12k interval they were still within specs. Oh ya compressed air is handy cause there is an incredible amount of dust and dirt that builds up under the gas tank and around the plugs etc., ya don't want that dropping into the valve train or plug holes.
    Cheers, Alex.
  3. #3
    DSBC Participating Member
    Join Date
    Jun 2005
    Posts
    170
    Post imported post
    Also - Screw the Robertson into a short piece of dowel so as to make it easier to hold.
    You can buy pre bent feeler gauges.
  4. #4
    Moderator Buck's Avatar
    Join Date
    Dec 2004
    Bike(s)
    DL,WR,DR,DT,KLX,TY
    Posts
    2,358
    Post imported post
    Picked up this simple DR valve adjustment kit from Jesse.
    http://www.kientech.com/ValveAdjustingToolKit.htm
  5. #5
    Join Date
    Nov 2009
    Bike(s)
    DRZ 400
    Posts
    813
    Post imported post
    Check out this link. Very helpful with pics as well:
    http://www.thumpertalk.com/forum/sho...d.php?t=649310
    If it doesn't work, let me know and I can e-mail you the pdf file.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
