Strauss Herb Company
Results 1 to 5 of 5
Thread: Radiator temp. sensor 2004 KLR
  1. #1
    DSBC Participating Member
    Join Date
    Mar 2005
    Location
    100 Mile House, British Columbia, Canada
    Posts
    51
    Post imported post
    The wire that connects to the radiator temp. sensor that runs the fan has corroded off. The local Kawi dealer wants $90 for a replacement. Could the wire be soldered back on? Is there an alternate (cheaper) non-Kawi sensor available? Thanks in advance for any tips.
    Sincerely,
    Slowly becoming more mechanically inclined.
  2. #2
    Join Date
    Feb 2005
    Location
    Mill Bay, British Columbia, Canada
    Posts
    566
    Post imported post
    I'm not sure of your exact problem but if it's just a wire off, then connecting it back together will solve it. You may have to connect it with crimp on connectors so you don't damage the sensor with the heat from your soldering iron.. Good Luck
  3. #3
    Join Date
    Oct 2004
    Location
    Kamloops, British Columbia, Canada
    Posts
    994
    Post imported post
    Dick, If it's part of the thermocouple then I think changing the wire (connector, solder etc,) may change the value (resistance) passing through it, which means the fan wouldn't come on at the right temp because you would have changed the calibration. Go to one of the radio places in 100 Mile and talk to an electronics tech. Or someone smarter than me may speak up here :P
    Doug.
  4. #4
    DSBC Participating Member joker650's Avatar
    Join Date
    Oct 2004
    Location
    Bike(s)
    SUPER ENDURO Yeaaah
    Posts
    4,251
    Post imported post
    Doug.
    Soldering will not affect or cause resistance in the circuit. If you crimp it, then iver time corrosion can start and this will cause a bad connection and eventualy the conection will start causing you problems.
    With all electrical repairs
    Solder and shrink tube the connection.(:P)
    My life has a superb cast, but I can't figure out the plot...
  5. #5
    Join Date
    Oct 2004
    Location
    Posts
    994
    Post imported post
    See? I knew there was someone smarter than me!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
